Hey Mudrat, That is one shot of Lil-Shiite on FR541-A twice, I know it can get confusing when you are getting old and when both XJ's are White. But Lil is the one with the Hella's 500's on the front bumper, and JD's is the one with the spare tire on the roof rack...... :oops: :roll: :shock: :smile: #-o :?: 111!!! :laughing3:
Here is a rear shot of what Mudrat posted, in fact that's Mudrat down the trail snapping pictures of whom every wanted to try to balance their rig, this was taken by Driwashjeeper he has the TJ behind Lil-Shiite on Saturday's ride......
It was rainy and so wet last Summer that this whole area was under water the cut under Lil-Shiite's left rear wheel was level with the right side of the trail, water ran thru this area so quickly that it actually had a current and it washed out nearly two feet of sand from the trail, the Ranger saved it by blocking the end with a Jeep trap or a four feet high mound of sand. In fact all of the trails in the St. Francis Area where running streams with a quick current, the St. Francis Area is only approximately 30 Square Miles of the nearly 1200 Square Miles that make up ONF..... :shock: :roll: 111!!! :!: :-| #-o
I know, it must have been all of that Guinness to much head for you..... :razz: :-s :-| [-X
I have already talked with the guy's that will be bring all of the equipment down from PA, there will be a Hemi 104, and/or a 6.6Ltd Scorp waiting for you at GWNF & MNF. I was just told that there maybe a couple of our new 101"WB RocBuggy's with 5.7L Hemi's (in lieu of SBC 6.3L, 6.0L or 5.7L) on some new 40" IROK Radials (I believe that some of you have seen them in a few of BFG's add's in the rag's that you read) Well, that's if your allowed to go....... :idea: :oops: :roll: :shock: :-| [-X
Later
Mark......
¬?,??¬§¬?{Com&Lil-Shiite}¬?¬§??,¬?¬?,??¬§¬?{X
J}¬?¬§??,¬?¬?,??¬§¬?{90-2DrSport}¬?¬§??,¬?¬?,??¬§¬?{M/T's&Locker's}¬?¬§??,¬?¬?,??¬§¬?{X
J}¬?¬§??,¬?
