Lifted79CJ7 wroteI used a big flat head screw driver and squished it between the spring and bushing. Then I would just hammer it in there to break the seal. I did this several times all the way around and kept spraying Valvoline lube in it and finally it came out....took a while though.
Rob tore up 2 of my chisles :smile: Had to take 1/4 off them to get an edge back!!
Roger on the press. The 20 ton shop press I have is what finally got Rob's apart after norking the crap outta the sleeves so we wouldn't keep pressing the socket in the eye. Had to use sockets, don;'t have the right sized press pins!!
