pitjeep
I want to replace the torex bolts in the diff cover with hex head bolts pros- cons stainless or steel ? also would like to raise trans &transfer case vents to inside body and put bigger breathers on them pros cons whats needed for this &where to find them the local auto people don,t have a clue
fuzz401
with stainless make sure u use never seiz
breathers go to a bearing house like brown bearing or applied a lot of gear box in industry use breathers might be able to fine some thing there
Lifted79CJ7
We were just talking aobut this on the Jeep-L, I believe both APC (the guys that make all the crap for ricers) and (not K&N, but they make blue colored filters)????? make breathers that look like tiny K&N filters for breathers. Also try a Google search. You will be able to find all kinds of stuff. As for raising the breathers, jsut tap the hole the beather goes in and put a fitting in there, then just run the hose to a breather up on the firewall. Hope this helps.
Jack
