newt
XLR8,
I sent you an email (if it worked). Could you run a couple combos for me?
All factors the same as jeepsr4ever's 401, but with the Crane 260-2 (which you used in your 360 example) and the Crower 276 HDP. Thanks. Let me know if you need any more info.
Dusty
jeepsr4ever wroteHopefully this engine will go into a postal jeep we are planning on building up :shock:
SAND DUNES ANYBODY
newt
Tim was kind enough to run some ##s for me, so I thought I'd post them for others to see.
401 w/ stock bore and heads, 9.5:1 comp, air gap dual
plane intake, 650 cfm TBI, and small tube headers. I'd like to run the Crane 260-2 cam (456/484 lift, 204/216 duration, 112 LCA) and the Crower 276HDP (464/488 lift, 212/220 duration, 112 LCA).
>Here's what DD2K says:
>Crane HMV-260-2
>RPM HP TQ
>2000 173 454
>2500 219 459
>3000 266 466
>3500 303 455
>4000 342 449
>4500 322 375
>5000 315 331
>5500 296 282
>6000 260 227
>Crower 276HDP
>RPM HP TQ
>2000 166 437
>2500 210 442
>3000 259 453
>3500 310 465
>4000 339 445
>4500 331 386
>5000 328 344
>5500 311 297
>6000 279 244
Due to the above I'll be going with the Crane 260 which I think will be a great setup for the daily driving, rock crawling, and weekend fooling around that I'll be using the jeep for. 450+ lbsft from 2K through 4K should be fun.
Thanks Tim.
hmm nice torque numbers! =D>
Dusty
Likewise A thank you goes out to Tim for running my numbers also
401 .30 over
Howards Cam #310021
.479/.479/lift
222/222 duration@.50
114 lobe seperation
9.8:1 Comp
Dual Plane Intake: R4B
770 Carb
Small tube headers
090 heads stockers @58cc
He guessed and ran the numbers based on a 109 intake centerline, the cam is ground straight up at 114, an i am thinking of trying to advance it 4 or 6 degrees. so 109 he hit it right in the middle of what i was thinking.
RPM HP TQ
2000 170 446
2500 217 455
3000 265 464
3500 321 481
4000 375 493
4500 398 465
5000 376 395
5500 366 350
6000 344 301
Sounds healthy, we will see what the real world numbers are, hopefully i get the thing on a dyno before i put her back in the jeep. I'm eager to wee how she idles too
Dusty
Nice numbers! I got one close to that I am putting together
Dusty
Found these Flow numbers on Edelbrock aluminium AMC heads here in the Archived thread about Edelbrock pricing way back
lift intake ex
100 65 52
200 130 96
300 192 127
400 235 163
500 258 182
600 260 190
Bore 4.195 (.030 over)
Stroke 3.68
Increases Compression ratio witht he Speed pro forged pistons from 9.8:1 with 58cc heads to 10.20:1 with Edel 54cc
Wondering how those flow numbers compare to stock AMC heads or if these numbers are truely an accurate representation of the flow of the Edel heads. Wonder how much the EFI will change the numbers along with the Heads
I'll have a rear wheel dyno sheet for you to compare to in january sometime I hope, its only been 6 months of planning
ol' school power
Low comp or not, that Summit 8600 cam really wakes up when you put a 750 on top instead of the 600.
