Got a scanner and can make color copies - - - it depends on if Jack shows up with it!!!
Also, If I don't get some issues resolved, I'll be there but will need to be somebodies spotter 'cause the Jeep won't be done. Found out today both rear rotors are made of composite and are warped badly - don't know if they can be turned down to spec. Haven't even gotten to the front end yet :smile: And, uh... I still have to fab the new front spring perches outboard on the frame to fit the wider axle, shock mounts, brake lines, etc... :oops:
I've been working way too much and not paying enough attention to the Jeep!!!
'Rat
ComChewy wrote
Hey Pat, If you have a scanner how about scanning it for me, if not if there is a Kinko's near by how about making a copy of the article and bring it with you next month.......
Many, many thanks...... Well, that's if you do it for me.......
Later
Mark......
