Too Much Fun Hey folks, I need help really bad. Went to lower my just completed 360 into my 79 CJ5 today and it wouldn't fit!! I have the CJ V8 mounts that attach to the frame, new rubber motor mounts, and the engine brackets that came with the motor when it was pulled from a 79 Wagoneer. Trouble is, with all of these bolted together, the entire assembly is too wide to fit between the frame rails. It ends up being about 2 inches too wide. What have I missed? The only thing I can tell is, is there is a different engine bracket that would attach to the rubber motor mount for the CJ? Some thing is terribly wrong!! Any help would be tremendously appreciated!!!! Thanks
Tigger Too Much Fun wrote.........the engine brackets that came with the motor when it was pulled from a 79 Wagoneer......... The engine mounted brackets for a FSJ are bigger than a CJ's due to the frame being about 5" wider
Too Much Fun Thanks for the reply!!! Does anybody know where I can get a set of the correct engine mounts? These two little items have got me at a stand-still. Thanks!!
pyagid FSJnovice wroteWould the 304 engine mounts work for him, somebody anybody? :t: :?: From a CJ yes
