J20 wroteThe pistons could have been .015 taller, need to shave about that much off the top of the block.
About half of that .015 is a math error from this post.
3.82+ 6.00 + 1.275 = 11.095, not 11.102. So 11.118-11.095 = .023 deck clearance, .007" more than your expected .016. Any idea where the remaining .008" came from? Was the piston compression height off from your expected 1.275"? Sorry if I missed the answer in the thread, I didn't see it. And why did you shave the block, was it to recover the desired compression ratio?
I'm exploring options to follow in your footsteps 😉 which is how I found this thread. I'm interested in offset-grinding the crank to increase stroke in combination with the 6" SBC rods to keep rod angle within reason, however I'm looking for a little more compression (10-10.5). I'll call Wiseco to discuss a custom piston, but wanted to fully understand your build first. Currently I've come up with these numbers to get my desired CR:
Stroke = 3.820 (place holder for now, a spun bearing will limit my stroke options)
Bore = 4.190 (same as your pistons)
Head volume = 57.92cc (stock)
Head gasket volume = 11.34cc (stock)
Piston volume = 20cc
Compression height = 1.290 (1.275 + .015 from your build)
If my numbers are right, that yields 421 cu. in. with .008" deck clearance and 10.5:1 CR. ??
Excellent writeup btw, thanks for sharing! 🙂
