FSJnovice wroteI like the sound of this and where it is going. Waiting for the rest of the info to be posted once comp dyno is done. :!: :t:
Well, a guy ran this for me on Dyno 2000, he used a stock cylinder though so it's not 500cubes, and open headers.... shoulda' been iron stockers, anywayz.... still impressive at only 452CI (I asked him to run it again at 4.374" cylinder for the 500CI):
***Note that this is on a stock intake and only 600cfm carb.
The Moldex crank used in the Indy "Bracket Master 500"
is 4.15" stroke,
probably safe to say that is probably the largest
stroke we will see for a
stock block (assuming the 401 block can be massaged to
clear those crank
throws). That nets 452.3 cubes with the 4.165 bore,
and 600 ft/lbs of
torque at 2000 RPM!!! (with Ultradyne's smallest
hydraulic (.517/.541 lift &
231/239 duration) AMC cam, stock big-valve dogleg
heads, stock intake,
600CFM 4bbl, small-tube headers w/mufflers, 10.2-1
compression). Not much
HP there, but loads of torque. I also tried adding
fully ported heads,
big-tube headers, big cam, big carb & Torker, the
rev-range is dictated by
the bore/stroke ratio, and 5500 RPM is peaked-out for
this one, no matter
how much cam, exhaust, or intake you throw at it.
Engine Power Torque
RPM (Fly) (Fly)
2000 229 600
2500 266 559
3000 304 532
3500 327 491
4000 320 420
4500 296 345
5000 256 269
5500 207 198
