durbs
I am trying to gather some parts up for my TJ to fit 35's on over spring break. I am probably going to get some re 3.5" coils, i bought a 1" body-lift and a rear track bar relocator bracket so far. Right now i have a tcase drop in and a re 2"bb so I am going to leave the tcase drop and just use the d3000's that came with the BB for now. What else do i need with this? An adjustable front tracbar? I got some 4.56 gears to put in at the same time too, as long as i had it that far apart I was going to put a lockright or ausie locker in front but...dont really have enough money plus i hear they only take like an hour to put in anyways eh?
Tigger
Durbs, Your RE 3.5" standard kit contains all the following:
RE1145 Front Sway Bar End Links
RE1155 Rear Sway Bar End Links
RE1172 Sway Bar Disconnects and Adaptor Bracket
RE1363 Front Coil Springs
RE1365 Rear Coil Springs
RE1380 Front 2" Bump Stops
RE1385 Rear 1.5" Bump Stops
RE1603 Rear Track Bar Bracket
RE2100 T-Case Lowering Kit
From what you have listed, execpt for a few items you have the kit.
durbs
hehe just talked to RE and they told me the same thing :sa:
Has anyone installed a lockright or aussie locker? I kinda want one for the front (cant stress the little 35 in the back anymore!) The reason this locker sounds good to me is because I would want to take it out in the winter and I hear it is very easy to install and take out.
Tigger
Called RE :roll:
Lockrites are simple, pull the axle shafts, drain the diff, pull the carrier, remove the ring gear, remove the spyders, install the lock right and remember the thrust washers, reinstall. if you have lower than 4.10's you don't have to pull the carrier or ring gear. Make sure you mark the bearing caps and the ring gear so you put it back in the same as you took it all out or you will need another gear setup.
Lifted79CJ7
So why just putting a locker in the front? Have the D44 with limited slip in the rear? I would go rear first for sure, if at all possible!
Jack
Lifted79CJ7
Also don't forget to make sure oyu have the correct carriers for your 4.56 gears!
Jack
durbs
yea i got new carriers with the gears so thats ready to drop in
the reason I am not going to do anything with the rear is because it isnt a 44 its a 35c :(: and putting 35's on that it going to be more then enough stress I think, if i had a better axle i would lock the back
