blmk9999 wroteThe one thing the accumulator will not do and was part of my thoughts in my original post, was the ability to continue to cycle oil through the engine to assis in cooling. The oil between the crank and the bearings probably boils after the engine is shut off normally. The accumulator could help with this, but then there is nothing to pre-lube the engine with. Maybe we can change the topic to pre and post lube. I'd still buy one.
Thanks,
Mark
Good thought - install 2 of them with button actuated solinoids (for remote operation without a handle) a green button for starting and a red one for shut down??? At $59 on Ebay (for the 1.5 qt units) it's not that expensive. You could use the same supply and return lines but different solinoids.
