If you groove your distributor as shown, you will increase the oil to it:
Everyone knows about the under-manifold line:
This is to be installed into the timing cover to oil the distributor
gear/timing chain:
TransAm pan as used on the Kaplan Javie:
I AM thinking of drilling and "jetting" one of the pipe plugs just above and beside the cam hole:
The inner side of the front of the block:
Self explanatory:
