Are you talking Wagoneer? Is it spring under the frame? If so, a Chev/Dodge RH drop D44 (or Ford highboy for LH drop) will bolt in. A touch wider than the pickup axle, but 7" of instalift in the front of mine. http://virtualjeep.com I got high steer arms that will clear the leaf springs w/o a spacer from http://www.ottindustries.com and used the stock Jeep tierods with longer centerlink and draglink center tube.
