engine wroteGot an '80 Cherokee Golden Eagle, 360 and 4-sp. Looking to get some ideas on where to look for a neusance water leak. When driven in rain, water leaks into the passenger side foot-well, comes down through the heater vent. I'm guessing a weep hole in the cowl area, but it really doesn't leak when it just sits while it rains. We thought it was in the wheel well, and tries sealing it with undercoateing and roofing tar, but didn't work. I heard this is a common thing with these trucks. Any one else?
Have you pressure washed the engine compartment? Did it leak then? If so there are a variety of places on the P-side under or around the battery tray - the computer harness, fan motor and the heater drain, bolts, etc.
If not pressure wash the windshield area for a few minutes. If you dont see any water, fold the windshield down and see if you've had encroachment past the rubber. This has been where mine have leaked in the past - air pressure pushes the water UNDER the rubber seal. If so you can get a new windshield seal OR I have used some 1/2 wide 1/4" thick door seal to stop the water from coming under the seal, it compresses nicely whan you put the winshield back up :wink:
Another area is the front door seal???
Let us know what you find out.
