jeepsr4ever Factory ratios 3.23-5.14 factory spline counts ??-30-33 Weak point carrier cap is prone to breakage through the bolt hole all full floating Beware of the 9 1/2 inch ring gear 14 bolt, it has a diamond shape cover
jeepsr4ever factory ratio 6.72 Full floater spline count 16 front or rear with the spice ujoint front being the more desirable Top pinion allows for Maximum lift and minimum driveshaft vibration Detroit locker available
Lifted79CJ7 Here is a great site for info: http://www.pirate4x4.com/tech/billavista/14b_bible/index.html Hope this helps, Jack
jeepgod all 14 bolt full floaters have the same axle shafts... they make up the width difference in the hubs... there is also a brand new spool through randy's ring and pinion going for around $250.... yes.. that is correct.. and its lighter than the stock carrier with a detroit.... and stronger.. the pirate link above is an awesome link.... plus these pigs are a dime a dozen... you can find these in ambulances... armored trucks.... buses..... bread trucks.. anything big.. will usually have a 14 bolt.. happy hunting :mrgreen:
