pyagid I have noticed a lot of talk about AMC heads here. I found this chart which gives specs on most years and designs of amc V8 heads and thought it may be helpfull t some http://www3.sympatico.ca/david.crooks/amc.PDF this is the same info taken from the site above sorry for the large image size
Lifted79CJ7 OK, so what cc would later AMC 401 heads be? This seems to be the same chart/info I find all over the net. I am having trouble figuring out how many cc's mine is so I can figure out what type pistons to order. Don't they get larger than 58cc's? Jack
Mudrat Lifted79CJ7 wrote Don't they get larger than 58cc's? Jack Jack, With the right tools ANYTHING can get larger :shock: 8) Mudrat
jeepsr4ever Frick that leaves it wide open Mud! Now where was my pic of the swedish made p#nis enlarger :?: :?: :?:
Gremlin4ever That "Rocker style" column, some are bridged and I understand that, thats how mine are. But the "single" ones, those I need to learn something on. Do those have guides or are those heads cast with the smaller pushrod holes as guides?
radjeeper I just installed a set of small chamber 390X heads on my 1978 401 with stock dished pistons. I believe stock compresion to be at 8.4 to 1. The best I can calculate using on on-line calculator I should now be at about 9.5 to 1. I'm wondering if any of you smart guys would know for sure?
tarior jeepsr4ever wroteFrick that leaves it wide open Mud! Now where was my pic of the swedish made p#nis enlarger :?: :?: :?: Shore am glad you didn't say "MY" swedish made p#nis enlarger 8)
5-90 pyagid;65737 wroteI have noticed a lot of talk about AMC heads here. I found this chart which gives specs on most years and designs of amc V8 heads and thought it may be helpfull t some http://www3.sympatico.ca/david.crooks/amc.PDF this is the same info taken from the site above sorry for the large image size Does anyone have this pdf that they could email to me? The link is no longer functional. Thank you!
